ilircepani
Dec 11, 2020Aspirant
Netgear AC1750 won't connect
I have internet through an Arris Modem (renting) through Xfiniti (the internet provider). I bought the Netgear AC1750 (Nighthawk), and went through all the app steps, and was on the phone directly wi...
Dec 11, 2020Guru - Experienced User
the TG1682g is a modem/router/phone device. it puts you in a double nat.
After putting it in bridge mode, after the reboot, power it off and disconnect all devices from it even the coax.
The connect coax back to it, power it on and give it a couple minutes.
Then connect the router and only the router to it. power the router on. give it a couple minutes.
Make sure you only connect the router to it. Comcast only gives out 1 public ip address and when the TG1682g is in bridge mode, it can only have 1 device connected to it.
ilircepani
Nothing again...
Durign the setup I put the blue cable of internet in Port1 and the ethernet cable in WAN of the router to one of the moded ethernet ports) and the Internet light of the router stays orange color, and the nighthawk app still says no internet.
- plemansDec 11, 2020Guru - Experienced User
You can try putting the Arris back in router mode and the netgear in access point mode.
thats another option.
