RBrogen
May 18, 2021Aspirant
Netgear AC1750
This unit was workin fine with Firmware version v1.0.4.84_10.0.58. I got the notice that there was a firmware upgrade available. I ran the upgrade and it completely bricked my unit. It now sits wi...
May 18, 2021Guru - Experienced User
many things can go wrong with tftp.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
one thing. This isn't netgear. this is the community support forum where members of the public try to help out.
- RBrogenMay 18, 2021Aspirant
Thank you for taking the time to reply plemans. I'm actually running it on a MAC. Yes I realize that this is the forum for members as I don't really anticipate Netgear actually assisting with the issue they caused with a crap firmware release. I may bring the unit to a different computer and try ftp from Windows.
- plemansMay 18, 2021Guru - Experienced User
I've never done it on a MAC but I've used tftp and nmrpflash several times on windows and its always worked for me.
- antinodeMay 18, 2021Guru
> [...] I'm actually running it on a [Mac]. [...]
Fine, but that still doesn't say how you did "manually TFTP the
firmware update", including which file you tried to send. Copy+paste is
your friend. There's a link to Mac instructions in this:
