RBrogen
May 18, 2021Aspirant
Netgear AC1750
This unit was workin fine with Firmware version v1.0.4.84_10.0.58. I got the notice that there was a firmware upgrade available. I ran the upgrade and it completely bricked my unit. It now sits wi...
May 18, 2021Guru - Experienced User
many things can go wrong with tftp.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
one thing. This isn't netgear. this is the community support forum where members of the public try to help out.
RBrogen
Thank you for taking the time to reply plemans. I'm actually running it on a MAC. Yes I realize that this is the forum for members as I don't really anticipate Netgear actually assisting with the issue they caused with a crap firmware release. I may bring the unit to a different computer and try ftp from Windows.
- plemansMay 18, 2021Guru - Experienced User
I've never done it on a MAC but I've used tftp and nmrpflash several times on windows and its always worked for me.
- antinodeMay 18, 2021Guru
> [...] I'm actually running it on a [Mac]. [...]
Fine, but that still doesn't say how you did "manually TFTP the
firmware update", including which file you tried to send. Copy+paste is
your friend. There's a link to Mac instructions in this:
