Dashyy
Jan 19, 2023Aspirant
Netgear AC1750
My internet went out while I was away on business, I came home paid my bill but now my bills is paid but my netgear won’t access internet now. Any ideas?
Jan 19, 2023Guru - Experienced User
What model# is the router you have?
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Dashyy
I have done all the above, right now it shows left to right 1 solid green then 2 green blinking, means it’s trying to connect but I’m not sure why it won’t
- michaelkenwardJan 20, 2023Guru - Experienced User
Dashyy wrote:
I have done all the above, right now it shows left to right 1 solid green then 2 green blinking, means it’s trying to connect but I’m not sure why it won’tWhat is your modem and has it connected to the Internet?
If the modem won't connect, the router can't either.
Have you fed the router with the login details for your ISP again?
