Fishels
Aug 21, 2022Tutor
NETGEAR AC1900 model R7000 is messing up my PlayStation 5 Bluetooth. Help
Hey there everyone. So about two weeks ago I noticed my audio would drop or stutter from my controller. At first I assumed a poor cable. But then I went on to test 3 different headsets same result. I...
Aug 22, 2022Guru - Experienced User
You can try changing which channels the router is broadcasting on. that might help if its caused by interference.
- FishelsAug 22, 2022Tutor
Can I ask is there specific channels for each band that might work? Like a starting off point.
Also why did this just start happening now a year in. That’s what confuses me
- plemansAug 22, 2022Guru - Experienced User
try channels 1-6-11.
There's options to turn off the ssid broadcast that doesn't actually shut off the 2.4ghz band but just disables being able to "see" the 2.4ghz. You might have hit that.
Thanks! Do you mean those channels in regards to the 2.4?
also how do I actually shut down 2.4 completely if I want to
