Fishels
Aug 21, 2022Tutor
NETGEAR AC1900 model R7000 is messing up my PlayStation 5 Bluetooth. Help
Hey there everyone. So about two weeks ago I noticed my audio would drop or stutter from my controller. At first I assumed a poor cable. But then I went on to test 3 different headsets same result. I...
Aug 22, 2022Guru - Experienced User
You can try changing which channels the router is broadcasting on. that might help if its caused by interference.
Fishels
Aug 22, 2022Tutor
Can I ask is there specific channels for each band that might work? Like a starting off point.
Also why did this just start happening now a year in. That’s what confuses me
- plemansAug 22, 2022Guru - Experienced User
try channels 1-6-11.
There's options to turn off the ssid broadcast that doesn't actually shut off the 2.4ghz band but just disables being able to "see" the 2.4ghz. You might have hit that.
