Fishels
Aug 21, 2022Tutor
NETGEAR AC1900 model R7000 is messing up my PlayStation 5 Bluetooth. Help
Hey there everyone. So about two weeks ago I noticed my audio would drop or stutter from my controller. At first I assumed a poor cable. But then I went on to test 3 different headsets same result. I...
Fishels
Aug 22, 2022Tutor
Can I ask is there specific channels for each band that might work? Like a starting off point.
Also why did this just start happening now a year in. That’s what confuses me
Aug 22, 2022Guru - Experienced User
try channels 1-6-11.
There's options to turn off the ssid broadcast that doesn't actually shut off the 2.4ghz band but just disables being able to "see" the 2.4ghz. You might have hit that.
- FishelsAug 22, 2022Tutor
Thanks! Do you mean those channels in regards to the 2.4?
also how do I actually shut down 2.4 completely if I want to
- plemansAug 22, 2022Guru - Experienced User
Yes, try those channels.
Thanks! What if it is my 5G That’s causing the issue? Are there recommended channels for that. I turned off 2.4 G completely (light was off) and still heard the interference. I’m exhausted at this point. I don’t understand why my router just decided to do this after all this time
