Fishels
Aug 21, 2022Tutor
NETGEAR AC1900 model R7000 is messing up my PlayStation 5 Bluetooth. Help
Hey there everyone. So about two weeks ago I noticed my audio would drop or stutter from my controller. At first I assumed a poor cable. But then I went on to test 3 different headsets same result. I...
Aug 25, 2022Guru - Experienced User
What brand and model head sets did you test?
Are these head sets wired or wireless?
I have a Turtle Beach Elite and Plantronics Rig Pro 500, both wired and don't experience any issues with my Xbox controllers or headsets.
You might try all wired heatsets to the game controller and wire the controller to the game console to test.
I gave up wireless headsets years ago due to some interference problem and having to maintain batteries.
Fishels
Aug 25, 2022Tutor
Wired. Always wired. I plug the headset into the controller because I don’t feel like dealing with the amp anymore lol. I have 2 Astro A40 headsets. Used a skull candy one and then a wired Sony.
When my controller is connected to the console(Bluetooth off mode)or when I use my amp I have zero issues.
- FURRYe38Aug 26, 2022Guru - Experienced User
Also sounds like a bad interference handling with the controller when it's wirelessly(BT) connected to the console. Something you might ask Sony about.
- FishelsAug 26, 2022Tutor
Contacting Sony? Why? It works perfectly at another residence as I have stated. And I have 3 different controllers tested. 2 for PS5 and one for PS4. I just can’t imagine what they would add to the conversation besides check your router and your neighbors
Believe me I wish it was a controller issue. I could simply replace or repair
And you turned OFF the wifi on the R7000 and checked with this configuration and still have interference problems?
Also had this been working before or has this been something that just started happening?
