CrimsonWildcat9
Sep 21, 2021Follower
NETGEAR AC1900 Nighthawk™ Dual-band Wi-Fi 5 router (R7000)
Is the AC1900 Nighthawk (R7000) compatible with the AX6000 WiFi Mesh Extender (EAX80)?
Sep 21, 2021Guru - Experienced User
Should be however may not be using the full capabilities of the EAX extender with the R7000 router. EX7500, 7700 or 8000 maybe a better fit with the R7000. Or you could disable the wifi radios on the R7000 and setup the EAX in AP more for more inproved wifi.
