zanm
Nov 09, 2015Tutor
Netgear AC1900 R7000 Multiple Xbox Ones Open NAT Type
Hi all, What is the best solution for multiple Xbox Ones on the same network. I have two Xbox Ones. My issue - getting an open NAT Type on both Xbox Ones. Both systems have an open NAT, but not...
- Nov 09, 2015
You can keep the IP addresses from changing by using Address Reservations. Log into the R7000. Go to ADVANCED > Setup > LAN Setup. At the bottom will be the Address Reservation section. Add two entries for your Xboxes.
TheEther
Nov 09, 2015Guru
zanm
Nov 09, 2015Tutor
TheEther,
Awesome!! I firgured there had to be a way to keep the IPs for both systems the same and never change. Thank you...now will this also fix my issue with both systems using port 3075 for black ops 3? I can only port forward one IP to use port 3075 UDP.
Again, thank you for the quick response...huge help!
m
