zanm
Nov 09, 2015Tutor
Netgear AC1900 R7000 Multiple Xbox Ones Open NAT Type
Hi all, What is the best solution for multiple Xbox Ones on the same network. I have two Xbox Ones. My issue - getting an open NAT Type on both Xbox Ones. Both systems have an open NAT, but not...
- Nov 09, 2015
You can keep the IP addresses from changing by using Address Reservations. Log into the R7000. Go to ADVANCED > Setup > LAN Setup. At the bottom will be the Address Reservation section. Add two entries for your Xboxes.
zanm
Nov 16, 2015Tutor
TheEther,
Thank you for your time and help and all the information provided. Yes, I agree...was hoping there was somehting I was missing to get two XB1's to share the same port. Only if COD games would go with dedicated servers (like TitanFall and BF did). I hope this happens one day. :)
Thanks again!
zanm
geoffnappi
Nov 20, 2015Aspirant
Did this work? ANd how do you assign addresses for each box...what numbers do you use?
- JamesGLNov 22, 2015NETGEAR Employee Retired
Hi Geoffnappi,
If you mean to say how to assign IP address on each Xbox, you may assign static IP on the Xbox settings itself or LAN IP reservation under LAN setup of the router's UI. The IP address should be within the range of the routers IP. For example: If your router's IP is 192.168.1.1 then you can assign static IP on Xbox starting 192.168.1.2 to 254.
