ProACTSam
Feb 21, 2021Aspirant
NETGEAR AC750 wifi adsl 2+ Modem Router - Doesn't Work is it a con?
This Netgear 35 series has never worked for us we have a wired cisco 800 modem so put it aside whne brought as a problem child - We want to use this new bit of kit again but cannot ket it to work ...
Feb 21, 2021Guru - Experienced User
What are you missing? lots of things.
1. This is the general routers forum. Not the dsl modem forum. So unless you have just a router (without modem integrated), your in the wrong forum.
https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers
2. AC750 is a speed and not a model. And "Netgear 35" is your ssid, not a model. You'd want to actually look at the device's label to see what model you have.
3. when you post in the proper forum, include the correct model number, the firmware on it, what steps you've tried, and where its failing in the process. That'll help people to see what you've tried and where its failed in setup. You also put you have fibre and adsl service. What one are you using?
