ProACTSam
Feb 21, 2021Aspirant
NETGEAR AC750 wifi adsl 2+ Modem Router - Doesn't Work is it a con?
This Netgear 35 series has never worked for us we have a wired cisco 800 modem so put it aside whne brought as a problem child - We want to use this new bit of kit again but cannot ket it to work ...
ProACTSam
that a great help thank you.
i will do as you suggest,
i have identified now the issue is my ISP use a static IP address outside the range of the device ie its not compateble,
