dmoreno62
Nov 17, 2020Follower
Netgear AC750 Wifi Range Extender
The WPS green light is off. This means the extended network is enabled without wifi security. Is this okay to use?
1 Reply
Is there security on the router?
Try reinstalling it using the installation assistant and not using wps
