GigiS
Nov 23, 2021Tutor
Netgear AX AX4300
I am currently on firmware V1.0.2.82. I need to update to V1.0.4.100. When I try to download the file on my PC it fails to unzip. I get an error on BHR page stating "Gui language file is invalid". ...
Nov 23, 2021Guru - Experienced User
What device are you trying on? I just downloaded it and extracted it without issues on a windows 11 device.
Once extracted, then you follow the manual update process.
I take it you have the RAX45 (ax4300 is a speed, not a model)
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
https://www.netgear.com/support/product/rax45.aspx
GigiS
Nov 23, 2021Tutor
Yes, I am RAX45. I tried on PC running Windows 10 (I checked for update and none available)
Thanks for responding. I believe I already tried both the links you sent
