GigiS
Nov 23, 2021Tutor
Netgear AX AX4300
I am currently on firmware V1.0.2.82. I need to update to V1.0.4.100. When I try to download the file on my PC it fails to unzip. I get an error on BHR page stating "Gui language file is invalid". ...
Nov 23, 2021Guru - Experienced User
For your future needs, Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
Thank you.
GigiS wrote:
I am currently on firmware V1.0.2.82. I need to update tyo V1.0.4.100. When I try to download the file on my PC it fails to unzip. I get an error on BHR page stating "Gui language file is invalid". I tried using my IOS app to download. Afer using IOS to download, I gewt "Firmware Check Error" Indicating There was a problem checking firmware update. Any help out there would be appreciated
GigiS
Nov 23, 2021Tutor
Thank you, I will post there also after I review for any one having same issue
