GigiS
Nov 23, 2021Tutor
Netgear AX AX4300
I am currently on firmware V1.0.2.82. I need to update to V1.0.4.100. When I try to download the file on my PC it fails to unzip. I get an error on BHR page stating "Gui language file is invalid". ...
GigiS
Nov 23, 2021Tutor
Yes, I am RAX45. I tried on PC running Windows 10 (I checked for update and none available)
Thanks for responding. I believe I already tried both the links you sent
Nov 23, 2021Guru - Experienced User
You were able to download it?
What were you using (program) to extract the file? The built in "extract all" or a seperate program?
Like I said, I just tried downloading the file.
