CsGyB
Oct 24, 2021Aspirant
netgear AX6/AX5200 RAX48-100NAS DNS address change not working
Hi, I have a netgear AX6/AX5200 RAX48-100NAS router and I wanted to change the primary and secondary DNS addresses to the servers OpenDNS uses. I was not able to make the change as after I hit the '...
CsGyB
Yes, I tried PC's running Windows 10 and Ubuntu Linux. I used Microsoft edge, Chrome and Firefox browsers without success.
Oct 24, 2021Guru - Experienced User
what modem/gateway do you have?
- CsGyBOct 24, 2021AspirantI own a NETGEAR CM700-100NAS cable modem
- plemansOct 24, 2021Guru - Experienced User
Are you using ipv6?
Have you tried a simple factory reset/reinstall?- CsGyBOct 24, 2021AspirantI'm not tech savvy enough to use ipv6 but if you feel it might help I will try to research it and learn how to set it up.
I factory reset my router twice to no avail. I tried to adjust the DNS setting via the nighthawk app but they were grayed out, wasn't allowed to make any changes
