jperiyar
Nov 30, 2020Aspirant
Netgear C6300 with Cox Preferred 150MBPS Plan gives away only 50 MBPS speed
I was earlier using COX modem with COX 150 MBPS plan where I was getting in the range of 180MBPS of download speed. But, when I switched my modem to NETGEAR C6300, the speed drastically reduce to s...
Nov 30, 2020Guru - Experienced User
1. how are you testing? wired/wireless?
2. Do you have a screen snip of the cable connections page and logs? that helps us check the connection.
3. If you have any spiltters, amplifiers, or cable attenuators in the coax line, i'd recommend removing them.
4. what modem/router was it before?
jperiyar
plemans Thanks for your response. Please find below my response.
1. I tried testing the wireless speed.
2. Sorry I am unaware of this. Where can I get them from.
Not sure if you are referring to this page.
3. I do not have any of them connected.
4. The earlier modem used was ARRIS TG2472
