jperiyar
Nov 30, 2020Aspirant
Netgear C6300 with Cox Preferred 150MBPS Plan gives away only 50 MBPS speed
I was earlier using COX modem with COX 150 MBPS plan where I was getting in the range of 180MBPS of download speed. But, when I switched my modem to NETGEAR C6300, the speed drastically reduce to s...
jperiyar
plemans Thanks for your response. Please find below my response.
1. I tried testing the wireless speed.
2. Sorry I am unaware of this. Where can I get them from.
Not sure if you are referring to this page.
3. I do not have any of them connected.
4. The earlier modem used was ARRIS TG2472
Nov 30, 2020Guru - Experienced User
1. make sure to test speeds hardwired into the router. this ensures that it isn't a wireless issue.
2. 30mbps is actually pretty decent if testing over 2.4ghz. Its slow over 5ghz. 5ghz is much much faster but it doesn't penetrate objects as well or broadcast as far
3. Pictures have to be approved by a moderator and can take days. If you click "choose file" and attach each photo individually, then I can download/look at them
4. the cable connections page is when you first log into the device (through the browser), you click on the internet icon. That'll bring you to the cable connections page. It shows the modems channels, signal strengths,etc. get that whole page.
5. here's how you get the events logs
https://kb.netgear.com/30008/How-do-I-obtain-the-event-logs-from-a-NETGEAR-cable-modem-modem-router
6. The arris was a 24x8 modem versus the C6300 is a 16x4 modem. The arris was better in terms of modem side. But regardless both should be able to hit 150mbps.
