ignaav
Oct 10, 2021Aspirant
netgear c6300v2 sustained speeds
Hi there, I have a Modem/Router c6300v2, and xFinity cable provider (400 Mbps / 20 Mbps). I have been testing the speeds for more than 2 weeks and the average is between 200-350 Mbps download, 5-11 ...
Oct 10, 2021Guru - Experienced User
A couple things.
1. the speed rating is just what its rated for "up to". that all depends on the isp. Some isp's are requiring docsis 3.1 connections for faster speeds.
2. it should still be able to hit 20mbps upload
3. do you have a screen snip of its cable connections page and event logs?
ignaav
Thanks for clarifying! I just wanted to make sure that that very slow upload speed should be sustained with the c6300v2, even being docsis 3.0 The last technician who checked the connection saw that we have a few splitters in the attic, I believe that must be the problem.
- plemansOct 10, 2021Guru - Experienced User
photos have to be approved by a moderator and can take a while.
If you click on 'choose file" and add them that router, we can see them quicker
