ignaav
Oct 10, 2021Aspirant
netgear c6300v2 sustained speeds
Hi there, I have a Modem/Router c6300v2, and xFinity cable provider (400 Mbps / 20 Mbps). I have been testing the speeds for more than 2 weeks and the average is between 200-350 Mbps download, 5-11 ...
ignaav
Thanks for clarifying! I just wanted to make sure that that very slow upload speed should be sustained with the c6300v2, even being docsis 3.0 The last technician who checked the connection saw that we have a few splitters in the attic, I believe that must be the problem.
Oct 10, 2021Guru - Experienced User
photos have to be approved by a moderator and can take a while.
If you click on 'choose file" and add them that router, we can see them quicker
