drortman's avatar
drortman
Netgear C7000 Speeds
If I plug my computer directly into my router via a network cable, I get speeds at over 100 Mbps.  If I use my computer via wifi, I only get speeds  of 15.77 to 36.87...I called my cable provider and...
  • plemans's avatar
    Apr 01, 2020
    Are you testing connected to the 2.4ghz or the 5ghz?
    5ghz is significantly faster than 2.4ghz.
    for instance, my orbi usually gets 20-30mbps average over 2.4ghz but over 5ghz, I can hit 400-500mbps depending on device.
