jguth21
Aug 20, 2021Aspirant
Netgear C7000v2 Upstream Light Blinks Randomly (No Internet)
Recently, my NETGEAR AC1900 Model c7000v2 has been acting up. The internet will go out randomly throughout the day and the upstream light blinks. Everytime the internet goes out, the upstream light b...
Aug 23, 2021Guru - Experienced User
photos have to be approved by a moderator. You can click on "choose file" and add one at a time
jguth21
Aug 23, 2021Aspirant
I added one photo at 5:48 PM. Were you able to see that?
- plemansAug 24, 2021Guru - Experienced User
it is showing now.
Your power levels look fine but you have errors in the line and your logs indicate line issues.
I'd check your link for kinks, damage, old/bad/cheap/poor/corroded connections.
remove any splitters or signal attenuators from the line
- jguth21Aug 24, 2021Aspirant
Ok thanks. I dont know anything about splitters or anything. I use I will call my ISP charter and have them come out again and look at the lines.
- jguth21Aug 26, 2021Aspirant
Hey, I replaced a cable from my modem to the wall. Is there anything showing on the event log that the upstream was messed up? I guess what should I look for?
- plemansAug 26, 2021Guru - Experienced User
photos have to be approved by a moderator. You can click on "choose file" and add it that route
