jguth21
Aug 19, 2021Aspirant
Netgear C7000v2 Upstream Light Blinks Randomly (No Internet)
Recently, my NETGEAR AC1900 Model c7000v2 has been acting up. The internet will go out randomly throughout the day and the upstream light blinks. Everytime the internet goes out, the upstream light b...
Aug 24, 2021Guru - Experienced User
it is showing now.
Your power levels look fine but you have errors in the line and your logs indicate line issues.
I'd check your link for kinks, damage, old/bad/cheap/poor/corroded connections.
remove any splitters or signal attenuators from the line
jguth21
Aug 25, 2021Aspirant
Hey, I replaced a cable from my modem to the wall. Is there anything showing on the event log that the upstream was messed up? I guess what should I look for?
