gregnsk
Dec 30, 2021Aspirant
Netgear C7800: can't connect to wifi, admin portal after a few hours
My Netgear C7800 works great after reboot. But several hours later all devices get disconnected from Wifi and can't reconnect. Login to 192.168.0.1 becomes very slow and eventually times out. The o...
gregnsk
Attached
gregnsk
- gregnskDec 30, 2021Aspirant
And here is the entire home network environment
- plemansDec 30, 2021Guru - Experienced User
2 things you try.
1. disable dos attack log. it can bog down the processor and it isn't really beneficial.
2. keep track of the times it slows down and you have to reboot it. Your logs have t3 issues but I'm curious if it relates to when you're having issues since there isn't an abundance of them. And when you reboot the router, it clears out the cable connections page/errors.
