gregnsk
Dec 30, 2021Aspirant
Netgear C7800: can't connect to wifi, admin portal after a few hours
My Netgear C7800 works great after reboot. But several hours later all devices get disconnected from Wifi and can't reconnect. Login to 192.168.0.1 becomes very slow and eventually times out. The o...
gregnsk
Dec 31, 2021Aspirant
I don't see anything special around this time in the logs. Is there any way to increase verbosity of the logging?
BTW, the modem continues to work, I can still access the Internet via wired connection to the Netgear.
It's wifi and the management console that become non-functional.
Dec 31, 2021Guru - Experienced User
When it happens, if you log into it and change the wifi channel, does it help?
- gregnskDec 31, 2021Aspirant
When it happens, I can't login to the management console - so I can't change anything...
- michaelkenwardJan 01, 2022Guru - Experienced User
As we are talking about the C7800, it wouldn't do any harm to browse around in the place where they talk about cable modem/routers:
That's probably here:
Cable Modems & RoutersThat device has plenty of questions and answers:
Search - NETGEAR Communities – C7800
- gregnskJan 01, 2022Aspirant
I checked the forum and didn't find my problem. There are several threads talking about ISP-related issues, where both Wifi and wired connections to C7800 fail.
In my case, wired connections have no issues - I'm still getting great Internet connectivity.
However, I'm not able to connect to WiFi. I'm also not able to connect to the admin interface of the C7800
