JRiley9898
Feb 25, 2021Aspirant
Netgear Cable Modem not getting full 1Gbps Speeds through Xfinity
Hello I recently upgraded my Xfinity plan to there 1Gbps speeds since my modem on the box States that it can support up to 1.9Gbps speeds just to find out it's not putting out the full speeds. I've ra...
Feb 25, 2021Guru - Experienced User
Xfinity requires a docsis 3.1 modem for gigabit speeds. The C7000 is only docsis 3.0. So you won't hit gigabit speeds on it.
the AC1900 are wireless specs and not the modems specs.
JRiley9898
Is there anything I can do to at least increase my upload without having to change out my equipment?
- plemansFeb 25, 2021Guru - Experienced User
You should be able to get faster uploads. When I was using the c7000, I was hitting 30mbps upload on xfinity.
Do you have a screen snip of your cable connections page?
you might also check with xfinity about getting it provisioned with a lower tiered speed like their 400/600mbps plan.
- JRiley9898Feb 25, 2021Aspirant
photos have to be approved by a moderator. so it can take a while. Your link I can view but it doesn't have all your info. Do you have the rest of it?
Your initial power levels are quite high.
