Intel_Graphics
Mar 27, 2016Aspirant
Netgear Centria Reset Button Does't Work
I have a netgear centria router and I lost the password to the router login. I tried pressing the reset button for 10 seconds and I also tried the 30 30 30 reset method, but both of those methods won...
- Mar 30, 2016
Time to buy a new one....
storm1985
Mar 27, 2016Prodigy
When you push the reset pin hole did you notice that the power LED is blinking amber or responding? If it doesnt respond when you push the reset then HW might be defective. if under warranty you may call support for a replacement.
Intel_Graphics
Mar 30, 2016Aspirant
The power led doesn't blink amber or respond. My unit is not covered by warranty anymore.
- storm1985Mar 30, 2016Prodigy
- Intel_GraphicsMar 30, 2016Aspirant
Rip
