Jord9857
Mar 13, 2021Aspirant
Netgear D7000v2 Setup
Hi there, I followed this - https://community.plus.net/t5/Fibre-To-The-Premises-trial/Netgear-Nighthawk-D7000-V2-VDSL-Set-Up-Ins... And also used the Netgear Genie 'autosetup' but just can't seem...
- Mar 14, 2021I completely reset & updated to the latest firmware which resolved the issue
antinode
Mar 13, 2021Guru
> I followed this - [...]
An example of a non-DSL connection? I wouldn't bet on its details
being appropriate. Have you asked your ISP about them? The ISP might
also be able to discern what's going wrong.
> [...] the lights are glowing white, [...]
White DSL and Internet suggest many correct parameters; I'd worry
about the VLAN-related stuff.
