forry's avatar
forry
Initiate
Apr 16, 2020
Netgear D7000v2
After I lose power on My Nighthawk D7000v2 e.g. a minor power cut, or If i unplug it from the mains, l always lose the internet. The router reboots and looks normal  but there is no internet connecti...
  • forry's avatar
    Apr 17, 2020
    I think I have found the fix. I changed a setting. So I went to setup.Under Wan Preference,I changed the setting from Must use DSL Wan to "Must use Ethernet Wan".Click apply.
    So to test it I turned the modem off  and repowered the device. And I  noticed the  internet connection on the router came back automatically.Yay.
