kenlaz
Nov 28, 2019Guide
Netgear does not support their product
After having bought several Routers from Netgear and many switches and other gear, I tried to get some technical support because there is a problem with WiFi bandwidth (wired bandwidth is fine), but ...
- Nov 28, 2019
Go for an ASUS, the AC86U is the current sweet spot until AX routers mature. Avoid TP-Link as they abandon their models pretty fast
microchip8
Nov 28, 2019Master
- kenlazNov 29, 2019Guide
Thank you for the helpful suggestion!
