kenlaz's avatar
kenlaz
Guide
Nov 28, 2019
Netgear does not support their product
After having bought several Routers from Netgear and many switches and other gear, I tried to get some technical support because there is a problem with WiFi bandwidth (wired bandwidth is fine), but ...
  • microchip8's avatar
    Nov 28, 2019
    Go for an ASUS, the AC86U is the current sweet spot until AX routers mature. Avoid TP-Link as they abandon their models pretty fast
