Liliana's avatar
Liliana
Tutor
Sep 26, 2017
Netgear ethernet cable light flashing amber and no connection to internet
Hi,   I am using Netgear Nighthawk x4 as my wireless router with an Arris SURFboard SB6141 modem to connect to the internet. I have Spectrum as my provider. All was fine for a couple years until ab...
  • joecop's avatar
    joecop
    Sep 26, 2017
    The method I described doesn't involve getting into the router to update the firmware.
