semechan
Nov 18, 2020Aspirant
Netgear Ex7000 SSID dropped every 3 hours after connected it to TELUS Optic Fiber Router
My Ex7000 router SSID kept dopping off every day which made those wireless connected divices disconnected. Those devices wried with ethernet cable to EX7000 are running fine. I have to reboot the EX...
Nov 19, 2020Guru - Experienced User
do you have it connected via wps or using the installation assistant?
You might have better luck posting in the extenders forum and not nighthawk router forum.
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
- semechanNov 19, 2020AspirantI install it via WPS. I have also checked the firmware, it is the latest version. Reset factory default doesn’t help too.
- plemansNov 19, 2020Guru - Experienced User
try installing it using the installation assistant. WPS can get coded different and cause issues between manacturers.
