Jeff_0926
Feb 19, 2021Follower
NetGear genie
I am currently taking a cyber security class and am needing to set my personal router to WPA-PSK [TKIP]. I can not find this option I have set mode: to 54 Mbps this option only displays WEP. Please an...
antinode
Feb 19, 2021Guru
> Model: R6400|AC1750 Smart WiFi Router
Is that accurate? R6400[v1] or R6400v2? Look for "Model" on the
product label. Firmware version?
> [...] I can not find this option [...]
Where did you look? What _did_ you find?
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for "Specify Basic WiFi Settings" and "Change the WiFi Security
Option".
As plain-old WPA is increasingly being considered obsolete, there's
some chance that you'd need to load an old/obsolete firmware version in
order to use it.
> I am currently taking a cyber security class [...]
Lesson zero:
