Zenithinfo
Jan 31, 2022Aspirant
Netgear Genie
Je veux utiliser AirPrint avec netgear genie, mais ça me demande d'avoir itunes et acrobat reader installés. Je les ai tous les deux, mais airprint ne va pas plus loin, je ne peux donc pas (plus) l'...
ValerieD
Feb 04, 2022Community Manager
Bonjour Zenithinfo,
Et bienvenue sur la Communauté NETGEAR! :)
Nous aimerions vous aider mais nous avons quelques questions ici.
Quel appareil NETGEAR utilisez-vous avec Genie?
"je ne peux donc pas (plus) l'utiliser"
Cela fonctionnait donc avant dans les mêmes conditions ou quelque chose a changé dans votre réseau?
Bonne journée à vous,
Valérie D
Equipe Netgear
Zenithinfo
Feb 04, 2022Aspirant
Hello,
I have used Netgear Genie as a software (not linked with a model, even if I use a Switch GS-305) , to print on my printer as an "Airprint" on my computer.
But now, it seems to be impossible, and when, I click on Airprint, Netgear Genie ask me to get iTunes and Acrobat reader. I have these 2 software installed, but Netgear Genies dont find them.
Thank you for your help.
- michaelkenwardFeb 05, 2022Guru - Experienced User
You refer to the genie. This could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
- ZenithinfoFeb 05, 2022Aspirant
I said, I use the he browser interface, on Windows.
Imposible to access AIr Print.
That is not the genie.
As the manuals explain, the "browser interface" is the graphical user interface (GUI) that uses your browser when you ask it to go to routerlogin.net.
The "genie" is one of several things, including the desktop software that you download from here:
genie | Product | Support | NETGEAR
That is not the "browser interface".
With airprint, the desktop genie lists the printers that "this computer can see".
To use airprint you need to set up the printer so that it appears in that list.
We have no idea which Netgear router you are using. (The GS305 isn't a router.)
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
Check the manual for how to set it up to work with airprint.
