Mike29
Nov 11, 2021Aspirant
Netgear GS305
I cannot figure out how to get multiple computers online at the same time like this device is supposed to allow me to. Does anyone know how I configure my computers to allow this? Thank You
Nov 11, 2021Guru - Experienced User
Never hurts to have a router that supports wifi. Wifi can be disabled for most of the routers (not the mesh ones) so you have the option of disabling it or using it. I'd look through the routers that are gigabit on the netgear routers page. You can filter by specs you want.
michaelkenward
Nov 12, 2021Guru - Experienced User
You might have a hard time finding a router that does not do wifi.
- plemansNov 12, 2021Guru - Experienced User
to not support wifi, you'd either want to look at the business grade routing solutions or you could check into something like the edgerouter x.
Or just get a standard router and disable its wifi.
- michaelkenwardNov 12, 2021Guru - Experienced User
Just press the "off" switch?
good point! there's the wifi on/off switch on most routers
