Mike29
Nov 11, 2021Aspirant
Netgear GS305
I cannot figure out how to get multiple computers online at the same time like this device is supposed to allow me to. Does anyone know how I configure my computers to allow this? Thank You
Nov 12, 2021Guru - Experienced User
to not support wifi, you'd either want to look at the business grade routing solutions or you could check into something like the edgerouter x.
Or just get a standard router and disable its wifi.
michaelkenward
Just press the "off" switch?
- plemansNov 12, 2021Guru - Experienced User
good point! there's the wifi on/off switch on most routers
