Cavalo123
Aug 26, 2021Follower
Netgear GS324 Swtich with Virgin Media Router
Hi, I've recently set up an unmanaged Netgear 24port (GS324) Gigabit Ethernet Switch from a Virgin Superhub (UK). Wireless speeds are clocking at 250mbps which is roughly in line with my 350mbps d...
michaelkenward
Aug 27, 2021Guru - Experienced User
Where is the switch on the network? It should be downstream of the router.
What is plugged into it?
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Switches - NETGEAR Communities
I will ask the Netgear moderator to move your message.
