Duster1
Jul 30, 2023Aspirant
Netgear Highthawk R8000 and wired HP printer
I have an HP Laserjet 404dn connected via CAT5 cable to the router. Light is on indicating the router sees printer. The printer also appears in the list of attached devices under Access Control, bu...
- Aug 04, 2023
Solved, and even less Draconian than I was expecting. I restarted the IP, then reset the router to assign the printer a fixed IP. Then restarted the router, but, no soap. So, I reset the router to assign the printer an automatic IP, retarted and again no luck. But, I cycled through those steps twice more, and third time was the charm. What ever had become a problem ceased to be. In any case thanks for the suggestion. I am still very curious about what might cause a sticky shift like that.
michaelkenward
Jul 31, 2023Guru - Experienced User
Kitsap wrote:
Highly unlikely your issue is a router problem. Suggest you look toward the operating systems you are running on your computer.
Indeed. The usual advice is to track down the printer connection utility from whoever made it.
Duster1
Aug 01, 2023Aspirant
The reason that I addressed the Netgear community is because there is a definable issue with the router.
The Router offers TWO lists. One is the connected devices the router allows other device on the network to see. The other list all the devices the router says are connected. One list does not list the printer - former, the other does. That is, the router explicitly is limiting the visibilty of the printer to precisely no one but the router it self. So, there is an issue within the router, possibly a setting that changed somehow (me, someone I let print, ?). My question is what might that setting be? I can wire the printer directly to the computer and things would be fine - for me. Other users would have a problem. I don't let my computer act as a print server.
- michaelkenwardAug 01, 2023Guru - Experienced User
Indeed, but probably not the issue that you think.
Sadly, those are notoriously flaky "feature" that can sometime miss connected devices. They can also remember devices that are no longer connected.
You can find many conversations here asking for help with "connected devices".
So it might be unwise to rely on that as a clue as to the problems with your printer.
Even then, you cannot say that the difference between those two readings is not down to how the printer is configured. It may be missing from one of those because it needs to be tweaked at the printer/computer end.
Did you even investigate the idea of using the HP utility to check the printer's status? Just in case your conviction that it is a router issue is incorrect.
- KitsapAug 01, 2023Master
Duster1 wrote:The reason that I addressed the Netgear community is because there is a definable issue with the router.
Repeat question: do you have access control enabled?
It is not unusual for a situation where access control is enabled/disabled and internal settings are not completely cleared when it is disabled. The only solution found was to perform a firmware default reset on the router with a from scratch reconfiguration. Importing a previously saved configuration file would just import the problematic data.
- Duster1Aug 02, 2023Aspirant
Thanks.
Access Control is enabled, and has been since I put the modem into service four or five years ago. I will try the firmware reset. I tend avoid the more draconian steps if there is something simple that someone can point me to.
- michaelkenwardAug 02, 2023Guru - Experienced User
Quite right too.
It can help to save the existing settings.
Then, if the problem persists after the reset you can restore those settings in the knowledge that the issue is something else. As Kitsap says, restoring the settings is not a good idea if the reset did mend things.
