helotbc
May 11, 2022Aspirant
Netgear is slowing graffic
I have a Nighthawk R7450. I get 600Mbps out of my cable modem. I get 400Mbps out of the router cable port and 250Mbps over wifi. I have read the cable and wifi ports are rated at Gbps speeds. Any ide...
May 12, 2022Guru - Experienced User
Make sure that qos, access control, traffic monitoring, and parental controls are all disabled on the R7450.
If they were enabled, try disabling them and rebooting the router. If that doesn't help, try a factory reset on it.
