Toan's avatar
Toan
Netgear logging not working
I enabled all options using Netgear Genie for logging but none of the sites I visited on the allowed/blocked sites would show up in the logs.  Below is the list of options I enabled:
Attempted access to allowed sites
Attempted access to blocked sites and services
Connections to the Web-based interface of this Router
Known DoS attacks and Port Scans
Port Forwarding / Port Triggering
Wireless access
-Toan
  • Toan's avatar
    Toan
    May 18, 2017
    Thanks for the reply James.  My router started logging again after I added a couple new entries, save, and did a complete shutdown/restart.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi Toan,
    1. Did you configure block sites?
    2. What is the firmware version of the router?
    • Toan's avatar
      Toan
      Hi James,
      Yes, I blocked severals sites (Security - Block Sites) and my firmware version is V1.0.3.36_1.1.25
      -Toan
      • JamesGL's avatar
        JamesGL
        Hi Toan,
        I have the same firmware but my logs shows sites I visited that are blocked and allowed.
        Try to reset the router and reconfigure it manually.
