jovdew
Nov 25, 2021Follower
Netgear M5 MR5200 no data network connection after factory reset
Dear all, I am having a Netgear Nighthawk M5 MR5200 in use. All fine till this morning when I performed a factory reset. After the reset: no data connection. The sim card is fine - tested an...
Nov 26, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Mobile Router products. Most of the people who watch that forum are more likely to have experience with mobile routers and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Thank you
