HelpNoInternet
Mar 12, 2023Aspirant
Netgear moden not giving me internet but working elsewhere plz help i have the R7000p dsl with D-lin
Mar 12, 2023Guru - Experienced User
You're missing a lot of info.
All we got is you have the R7000P with dsl.
What dsl modem do you have?
Is this a new purchase?
What firmware is on the router?
Whats all going on? Not just "not giving me internet" but in detail of what errors or issue is going on
- HelpNoInternetMar 12, 2023AspirantModem is D-link dsl-520B
I use centrylink 10meg line $45 a month
Firmware 1.0.0.50
Old purchase so netgear won't help me without spending more then I spent on the router- michaelkenwardMar 12, 2023Guru - Experienced User
Firmware 1.0.0.50
Old purchase so netgear won't help me without spending more then I spent on the routerReset everything and set it up from scratch.
Important when you have second hand kit.
If that doesn't work, we need more details.
Blank messages don't help.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)They are there for a good reason.
- plemansMar 13, 2023Guru - Experienced User
The D-link, even though it says modem device, has some routing capability because it advertises as having a firewall and QoS. Meaning its got its own routing functions built into it.
So try logging into it and putting the netgears IP address into its DMZ.
