-Uzzi-'s avatar
-Uzzi-
Follower
Oct 12, 2021
Netgear Mr2100 e antenne LTE esterne
Buongiorno a tutti, sto per acquistare il Netgear Mr2100 per poter effettuare delle dirette streaming all'esterno tramite rete mobile, tuttavia vorrei anche acquistare delle antenne esterne poichè molto spesso gli eventi sono in aule con poca rete e posizionando un'antenna esterna sarei più sicuro della buoina ricezione.
Potreste indicarmi delle antenne per rete mobili compatibili con il Netgear Mr2100?
Grazie
Hello everyone, I'm about to buy the Netgear Mr2100 to be able to make direct streaming outside via the mobile network, however I would also like to buy external antennas as very often the events are in classrooms with little band and placing an external antenna would be safer of good band.
Could you please tell me about the mobile network antennas compatible with the Netgear Mr2100?
Thanks
1 Reply
  • michaelkenward's avatar
    michaelkenward
    -Uzzi- wrote:
    Hello everyone, I'm about to buy the Netgear Mr2100 ...
    That's not one of the Nighthawk WiFi Routers covered in this section. Questions about that are best asked in the appropriate section.
    That's probably here:
    Mobile Routers, Hotspots & Modems
    Those things are very different from the standard Netgear routers covered in this section.
