onenicelady
Mar 27, 2021Follower
Netgear N900 wireless dual band Wndr4500 Router is this too old?
I just purchased this router but it says windows 7 on the box. I am wondering if this can be used with Windows 10? also Comcast because I have wireless service with them
antinode
Mar 27, 2021Guru
> [...] I am wondering if this can be used with Windows 10? [...]
"wondering"? Have you tried it? Don't borrow trouble?
IP networking did not change fundamentally between Windows 7 and 10.
There might be some fine print involving ReadySHARE and SMB1.
> [...] also Comcast because I have wireless service with them
Ask Comcast? You have some modem or other? I wouldn't expect the
router to care.
- wcalifasMar 28, 2021Prodigy
yea that router works with windows 7, windows 10 or whatever other windows. Connect your computer via wifi or wired and type www.routerlogin or 192.168.1.1 to run the wizard to detect your internet and make any changes you want.
