FlyboyData's avatar
FlyboyData
Follower
Jun 14, 2017
Netgear Night Hawk R8000-vlan guest network
Hi,
I realize we might be trying to inappropriately use a home product here :-)
I've got a Night Hawk R8000 AC3200 Tri-band router that's running in access point mode.
I would like the guest network to use 802.1q tagged vlans.
The appropriate menu on the access point setup is grayed out: VLAN/IPTV setup.
Per this article here, it's the expected behavior: https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
Is there any workaround for this?
  • Hi FlyboyData,
    This is correct. Most features of the router are disabled when set to AP mode.
  • JamesGL's avatar
    JamesGL
    NETGEAR Employee Retired
    Hi FlyboyData,
    • JamesGL's avatar
      JamesGL
      Hi FlyboyData,
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
