andyamstrad's avatar
Aug 16, 2021
NETGEAR Nighthawk 11AC 2200 without WPS
Hi    I am trying to setup the Netgear WIFI Extender without WPS (Router does not have a WPS button).   When I look for the Netgear default SSID in WIFI Connections, it is not available only two ...
  • andyamstrad's avatar
    andyamstrad
    Aug 16, 2021
    I tried holding for 30 seconds and it worked!!  Seems you have to press longer than is specified.
    Thanks for your help, I am all up an running now. :-)
    Would like to say thankyou for a great forum.
