sidjain
Oct 29, 2021Follower
Netgear Nighthawk 1750 choking/blocking speed
Hi, I have Comcast/xfinity plan of 800 Mbps. I use a nighthawk CM 2000 modem which shows speeds of >750 Mbps when directly connected via ethernet to my laptop. However. when using wifi using the A...
Oct 29, 2021Guru - Experienced User
Youll not see anything near 800Mpbs on 5GHz wireless speeds with this router. This router is not capable.
